CAD Export
Learn about the CAD readers supported by HyperWorks and the options available for exporting CAD geometry data.
CAD writers are dynamically loaded upon demand.
View new features for HyperWorks 2021.1.
The following file types can be read, depending upon the active application.
Create a new file.
Open a file.
Import various file types into the selected client.
When loading an .hm file, you may receive a warning message depending on the version and solver interface in which the file was last saved.
Load a different solver interface in HyperWorks.
Load command files, scripts, solver template files, preferences, or the Metadata Table.
Save all of the data in your current session.
Export various file types from the selected client to another format.
CAD writers supported by HyperWorks.
CAD writers provide options for processing data during export.
When a CAD file is exported from HyperWorks, a .msg file is created (or appended to) in the current working directory.
Export solver input files.
Export plot data in several different formats so that it can be read by other software applications.
Learn about exporting connector files.
If you insert special comment cards into your input deck, you can provide HyperMesh with additional information about the colors and names of entities. You can also use comments to preserve information that is not supported by a particular solver, for example, assemblies or system references.
Export settings for AMF, AVI, H3D, JPEG, and GIF files.
Most FEA solvers allow you to organize the input deck into separate files and provide a mechanism to include (or refer) these files in the main input deck.
Record a video or take a snapshot of the screen.
HyperMesh composites modelings.
ON THIS PAGE
ON THIS PAGE
