Load Files
Load command files, scripts, solver template files, preferences, or the Metadata Table.
  1. From the menu bar, go to File > Load.
  2. Select file to load.
    Note: Options may be disabled, depending on the application you are using.
    If you are loading a Do this
    Command file / script / solver template In the Open dialog, navigate to your working directory and open the file to load.
    Preference file In the Preferences dialog, select the registered preference and click Load.
    Metadata table
    1. In the Meta Data dialog, Select XML file field, navigate to your working directory and open the file that contains metadata.
      File and curve metadata information is displayed.
    2. Copy and paste Templex statements for the tagged information into supported entities. These entities include notes, axes, page titles, and window headers/footers for use in a HyperWorks session.
    3. Click Close.
The current file is cleared from the memory, and the new file opens.
Metadata Table
Use the Metadata Table to access, review and use metadata information that is read from a file.
Metadata is information that describes the contents and context of the file.
From the Metadata Table, you can access the file's metadata and copy and paste Templex statements for the tagged information into supported entities. These entities include notes, axes, page titles, and window headers/footers for use in a HyperWorks session.
Supported file types include:
  • .xml files
  • ADAMS files with .xml information in the header
