HMASSEM_ID
Import comment to sort and organize entity types into HyperMesh.
HMASSEM_ID assembly id(s)
HyperMesh Comments
- assembly id(s)
- A list of identification numbers.
Supported Solvers
Nastran
View new features for HyperWorks 2021.1.
The following file types can be read, depending upon the active application.
Create a new file.
Open a file.
Import various file types into the selected client.
When loading an .hm file, you may receive a warning message depending on the version and solver interface in which the file was last saved.
Load a different solver interface in HyperWorks.
Load command files, scripts, solver template files, preferences, or the Metadata Table.
Save all of the data in your current session.
Export various file types from the selected client to another format.
Learn about the CAD readers supported by HyperWorks and the options available for exporting CAD geometry data.
Export solver input files.
Export plot data in several different formats so that it can be read by other software applications.
Learn about exporting connector files.
If you insert special comment cards into your input deck, you can provide HyperMesh with additional information about the colors and names of entities. You can also use comments to preserve information that is not supported by a particular solver, for example, assemblies or system references.
Associate an existing node to an existing surface.
Import comment to sort and organize property types and info into HyperMesh.
Import comment that indicates the beginning of the model documentation into HyperMesh.
Continuation card for the HMBEAMSEC card.
Preserves the style information for load curves.
Points to a material database file for the solver.
Defines the base location of a velocity load in HyperMesh.
Import comment to sort and organize design properties into HyperMesh.
Import comment that indicates the end of the model documentation into HyperMesh.
Preserves the ADMASS card upon import in Radioss.
Export comment that detects a problem upon export.
Describes weld points for the automesher.
Import comment that indicates the beginning of the footer for the deck.
Import comment that indicates the end of the footer for the deck.
HMFLAG
Defines a conduction group identification number in HyperMesh.
Change the input component of an element.
Defines a global origin for the analysis.
Gives the date and time that the deck was written and serves as a signal that the deck was created by HyperMesh.
Preserves plot element information in solvers that do not support plot elements.
Re-associate nodes/systems with their local systems.
Import comment to sort and organize entity sets into HyperMesh.
Import comment to associate support loads into a load collector in HyperMesh.
Preserves tag information in solvers that do not support tags.
Import comment to indicate to the reader that information in this section should be retained in the unsupported area of HyperMesh.
Import comment to color an entity in HyperMesh.
Export settings for AMF, AVI, H3D, JPEG, and GIF files.
Most FEA solvers allow you to organize the input deck into separate files and provide a mechanism to include (or refer) these files in the main input deck.
Record a video or take a snapshot of the screen.
HyperMesh composites modelings.
ON THIS PAGE
HyperMesh Comments
Nastran
ON THIS PAGE
