LS-DYNA to PAM-CRASH Mapping
Elements
LS-DYNA | PAM-CRASH |
*ELEMENT_SHELL | SHELL |
*CONSTRAINED NODAL RIGID BODY | RBODY/MTOCO |
*ELEMENT BEAM | SPRGBM |
*BOUNDARY SPC NODE | BOUNC |
*CONSTRAINED NODE SET | MTOCO/NODCO |
Sets
*SET_SHELL_LIST | Element set |
*SET_NODE_LIST | Nodes set |
*SET_PART_LIST | Component sets |
Contacts
*CONTACT_AUTOMATIC_GENERAL_ID | CNTAC46 |
*CONTACT_AUTOMATIC_SINGLE_SURFACE_ID | CNTAC36 |
*CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_ID | CNTAC33 |
*CONTACT_TIED_SHELL_EDGE_TO_SURFACE_BEAM_OFSET_ID | TIED |
Property
*SECTION_BEAM | PART_1D (BEAM) |
*SECTION_BEAM(SpringBeam) | PART_1D (SPRINGBM) |
*SECTION_SHELL | PART_2D |
*SECTION_SOLID | PART_3D |
