Thermal Event
Define a Temperature (Linear Static) loadcase.
Figure 2. View new features for HyperWorks 2021.1.
HyperMesh composites modelings.
Technology and problem evaluation approaches used in SnRD.
Explore the SnRD Pre-Processing user interface.
Use Setup Group to setup evaluation lines and define loadcases.
This tool is used to import all data required for the Squeak and Rattle Analysis preparation.
Use Define Interface tool to create, import and edit geometric lines.
Use Create E-Lines tool to create evaluation lines at component interfaces.
Use Manage E-Line tool to review and manage E-lines.
Setup loadcases to solve and extract results.
Define a Modal Transient (MTRAN) loadcase.
Define a Static (Linear Static) loadcase.
Create Single Point Constraints (SPCs).
Variability Study allow you to examine how squeak and rattle risks are affected by manufacturing variations.
Use Manage E-Points to modify local system collectors and evaluation points.
Evaluate Loadcase and export solver deck.
Explore SnRD Post Processing User Interface.
Use of Altair Ziegler SnR Material Database.
Figure 2. (c) 2021. Altair Engineering Inc. All Rights Reserved.
