Import Model
This tool is used to import all data required for the Squeak and Rattle Analysis preparation.
You can import a Model file as a Solver Deck (.fem) or a HyperMesh Database file (.hm). Also import and restore a previous session with existing E-Lines.
At this step, you can import a DTS file containing predefined Gap and Tolerance values for all the interfaces to evaluate and a Material Database file with compatibility data from Stick-Slip tests. If a material database file is unavailable you can connect to Ziegler Material Database.
To import a model file:
Import Options
Description of various Import options.
- Model File
- The user-defined DTS data is imported, and you can map an Interface Name to the corresponding E-line in Manage E-line. Supported file formats are:
- DTS File
- The user-defined Material database is imported, and you can map material to corresponding squeak lines in manage E-lines.
- Material File
- A connection to Ziegler Database is maintained and you can map material from the database to squeak lines in Manage E-lines.
