poITensorDefine SetCornerDataEnabled
Sets the use corner data state for a result definition.
poITensorDefine_handle SetCornerDataEnabled corner_data
HyperView Tcl Modify
This command, valid only in Upfront Data Loading Mode, sets the use corner data state for the result definition.
Note: The result definition can only be modified if it not cached.
corner_data
True to use corner data, false to not use corner data.
To enable the use of corner data for this result definition:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle tdefine 3 tensor
tdefine SetCornerDataEnabled true
hwi CloseStack
None.
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
