poITensorDefine GetCornerDataEnabled
Gets the use corner data state.
poITensorDefine_handle GetCornerDataEnabled
HyperView Tcl Query
This command, valid only in Upfront Data Loading Mode, returns true if use corner data is enabled for this result definition, false otherwise.
To get the use corner data state:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle tdefine 3 tensor
tdefine GetCornerDataEnabled
hwi CloseStack
None.
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
