poITensorDefine GetSelectionSetHandle
Gets the poISelectionSet handle of the result definition.
poITensorDefine_handle GetSelectionSetHandle handle modelID
HyperView Tcl Query
This command, valid only in Upfront Data Loading Mode, returns the poISelectionSet handle of the result definition which represents the set of entities associated with this result.
handle
The set handle to populate.
modelID
The ID of the model to be associated with the selection set.
To get the selection set for a result definition:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle tdefine 3 tensor
tdefine GetSelectionSetHandle set_handle 1
hwi CloseStack
None.
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
