Feko is a comprehensive electromagnetic solver with multiple solution methods that is used for electromagnetic field analyses
involving 3D objects of arbitrary shapes.
EDITFEKO is used to construct advanced models (both the geometry and solution requirements) using a high-level scripting language
which includes loops and conditional statements.
Feko offers state-of-the-art optimisation engines based on generic algorithm (GA) and other methods, which can be used
to automatically optimise the design and determine the optimum solution.
A graphical approach to define an optimisation search. More complex scenarios is handled by a mask, where the goal
shape is visually known, for example, the desired bandpass and bandstop regions of a filter.
Each part of the definition in an optimisation goal serves a specific purpose and should be correctly understood and
applied for the desired optimisation outcome.
Specify the method for combining multiple goals. A weight or importance factor is assigned to the combined goal and
optimised according to the combination type, for example, the average of the goals combined for the specified data.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application allowing you to create
models, get hold of simulation results and model configuration information as well as manipulation of data and automate
repetitive tasks.
