Launching OPTFEKO (Linux)
Use the most suitable option for launching OPTFEKO in Linux.
- On the Solve/Run tab, in the
Run/Launch group, click the
OPTFEKO icon.
- Launch OPTFEKO from the command line in a
terminal environment.
- Open a command terminal. Source the script “initfeko” using the absolute path to . /home/user/2021.1/altair/feko/bin/optfeko
- In the terminal (assuming the model with file name
dipole.cfx is to be optimised) type the
following command
and press Enter.optfeko dipole
Note: The above steps will launch OPTFEKO without any special settings. It is also possible to use parallel processing for optimisation.
