Defining an Optimisation Goal
An optimisation goal defines the solution request type to be optimised and the goal it will attempt to achieve.
- In the model tree under Optimisation, select a search for which you want to add a optimisation goal.
On the Request
tab, in the Optimisation group, click the
Add goal function icon.
From the drop-down list, select one of the following:
Impedance goal
Near field goal
Far field goal
Power goal
Receiving antenna goal
S-matrix goal
Transmission/reflection coefficients goal
SAR goal
