Launching OPTFEKO (Windows)
Use the most suitable option for launching OPTFEKO.
- On the Solve/Run tab, in the
Run/Launch group, click the
OPTFEKO icon.
- From the command line in a terminal environment.
- On the desktop, click the Windows Start button.
- Type Feko + WinProp 2021.1.
- Select the
Feko + WinProp 2021.1 icon, from the list of filtered options.
- On the Tools tab,
select the Feko terminal
icon.
- In the terminal (assuming the model with file name
dipole.cfx is to be optimised) type the
following command
and press Enter.optfeko dipole
Note: The above steps launches OPTFEKO without any special settings. It is also possible to use parallel processing for optimisation.
