Creating the Plate
Create the plate. Apply the UTD solution method to the plate.
Create the plate.
Create a rectangle.
- In the Workplanes group in the tree, right-click on Global YZ and select Set as default.
- Definition method: Base corner, width, depth
- Base corner (C) = (-3, 0, 0)
- Width (W) = 6
- Depth (D) = 3
- Label: metal_plate.
Create a rectangle.
- Set the default Workplane to Global XY.
Set the UTD solution properties on the metal_plate
part.
Tip: Open the Face properties dialog and click the Solution tab. From the Solve with special solution method list, select Uniform theory of diffraction (UTD).
