Viewing the Results
View and post-process the results in POSTFEKO.
The coupling results are derived from the received power data. In POSTFEKO the received power may be plotted on a graph. It is also given in the .out file.
Model | Received power (mW) | Coupling (dB) | Runtime (s) |
Full model | 3.03 | -45.55 | 100 |
Far field pattern | 2.61 | -45.85 | <12 |
Spherical modes | 2.62 | -45.82 | <12 |
Near field | 2.67 | -45.74 | <12 |
For convenience results were computed over a frequency range and plotted on a graph in POSTFEKO.
![](../../../../images/feko/example_guide/EG_B02_antenna_coupling_ideal_rx/graph_coupling.png)
Figure 1. Coupling results over a frequency range for the four models.
