Creating a Wire Port and Setting the Frequency
Add a wire port and voltage source to the Yagi-Uda antenna.
  1. Add a wire port (segment) to the middle of the yagi_active element.
    Tip: The yagi_active element is inside the Union1 part and cannot be selected directly for the wire port. In this case the correct Wire in the details tree of the Union1 part should be selected. Alternately, use edge selection and click on the wire in the 3D view coincident with the yagi_centre named point.
  2. Add a voltage source to the port. (1 V, 0°, 50 Ω).
  3. Set the frequency to freq.
