Delete a Folder or a File
Delete a folder(s) or file(s) that you no longer want.
  1. Click the Files tab located in the upper left-hand of the page.
  2. Using the file system tree on the left, navigate to the path from where you want a folder or file to be deleted.
  3. Perform one of the following options:
    • Right-click on the folder that you want to delete.
    • Right-click on the file that you want to delete.
    • Right-click on the folder and file that you want to delete.
    Tip: You can also select multiple folder or file. Select the first folder or file by clicking its name and hold down CTRL and select each folder or file by clicking its name.
  4. Select Delete.
  5. Click Yes.
    The folder or file is removed.
