Log into Access Web
Login to Access Web so that you can submit and monitor jobs.
Review the supported browsers before logging into Access Web.
  1. Enter the URL https://<hostname>:4443/pbsworks in the address bar of a supported browser.
    where <hostname> is the IP address or hostname of the machine where Access Web is installed.
    The Access Web login screen is displayed.
    Trouble: Contact an Altair Application Engineer if you are unable to access the login screen.
  2. Enter your username and password.
  3. Click Log In.
    Note: A localhost cluster is added by default, if Access Web is installed with PBS Application Services (PAS).
    Local Host Cluster
    Figure 1. Local Host Cluster
You can now submit a job.
Trouble: If the below message is displayed after logging in, a service cluster must be added. Only users that have been assigned a Manager role can add service clusters.
Manage Services - Clusters Information
Figure 2. No Clusters Available
