Move a Folder or a File
Move a folder or a file from one location to another within a server.
Tip: You can also use Cut and Paste option to move a folder or a file from one location to another.
  1. Click the Files tab located in the upper left-hand of the page.
  2. Using the file system tree on the left, navigate to the location where you want to move the folder or a file.
  3. Select the folder or a file that you want to move.
    Tip: You can select multiple folder or a file to move. Select the first folder or a file by clicking its name and hold down CTRL and select each folder or a file by clicking its name.
    Figure 1. Move Folder or a File
  4. Drag the selected file to the destination.
    Figure 2. Move Folder or a File to Destination
    Tip: You can also move the folder in the file system tree on the left by dragging the folder from one location to another.
