Download Folder or File
Download folder(s) or file(s) to your local machine.
  1. Click the Files tab located in the upper left-hand of the page.
  2. Using the file system tree on the left, navigate to path from where you want to download folder or file.
  3. Perform one of the following options:
    • Right-click on the folder that you want to download.
    • Right-click on the file that you want to download.
    • Right-click on the folder and file that you want to download.
    Tip: You can also select multiple folder or file. Select the first folder or file by clicking its name and hold down CTRL and select each folder or file by clicking its name.
  4. Select Download.
    The folder will be zipped and downloaded locally. It can be accessed from the default download folder on the local machine.
