File Operations
Perform file operations like edit and save, download, tail and delete the files.
You can perform the following file operations:
Icon Description
View file details such as the last modified timestamp, owner, and file size.
Download the file to your local machine.
Opens an edit session so that you can modify the contents of the file.
In the Edit mode view, you will have Save and Cancel options.
To refresh the file contents and to view the last lines of a file.
In the Tail mode view, you will have Play, Pause, and Stop options.
Provides an option for deleting the file from the remote server.
