Create a Folder
Organize job files by creating a folder or a subfolder.
  1. Click the Files tab located in the upper left-hand of the page.
  2. Using the file system tree on the left, navigate to where you want to create the new folder.
    Tip: If you are using this folder or file frequently, then click to bookmark this folder or file navigation path.
  3. Perform one of the following options:
    • Click New located in the upper right-hand of the page and select Folder from the menu.
    • Right-click in a blank space in the folder list and select New Folder.
    The Create New Directory dialog box is displayed.
    Figure 1. Create New Directory
  4. Enter the name of the folder.
  5. Click Save.
