Unzip a File
Unzip the file to extract the files or folders.
  1. Click the Files tab located in the upper left-hand of the page.
  2. Using the file system tree on the left, navigate to the location where you want to unzip the file.
  3. Right-click on the zip file.
  4. Select Uncompress.
    Figure 1. Uncompress a File
    The zip file will extract the contents and create a folder in the same path.
    Figure 2. Unzipped File
  5. Double-click the unzipped folder to check the contents.
