Add a Sub-Period
Add a sub-period for an already created period or sub-period.
Only an Budget Manager administrator can add a sub-period.
Periods can be divided into sub-periods and then the sub-periods can be further divided with a maximum depth restriction of ten. For example, a period can be adding representing the year 2019. Sub-periods for the parent period can be added representing yearly quarters. The quarters can then be further divided into months, the months can be broken down into weeks, and weeks can be broken down into days.
Sub-Period Example
Figure 1. Sub-Period Example
  1. Click the Configure tab.
  2. Click Periods from the Budget Manager menu located on the left-hand side of the web page.
  3. Click located to the right of the period or the sub-period (the parent period).
    Add a Sub-Period
    Figure 2. Add a Sub-Period
  4. For Period Name, enter a name that represents the sub-period.
    The name of the sub-period must be unique, i.e., there are no other periods or sub-periods having that name. Valid characters are A-Z, a-z, 0-9, underscores, dashes, period, tilde (~).
  5. Enter a start date and end date for the sub-period:
    The start date and end date of the sub-period must be within the range of the parent period.
    1. For Start Date, use the calendar widget to choose a start date.
    2. For End Date, use the calendar widget to choose an end date.
      The end date must be greater or equal to the start date and cannot exceed the end date of the parent period.
  6. Click Submit.
    The sub-period is added.
