Remove a Cluster
Remove a cluster that is no longer needed.
Only an Budget Manager administrator can remove a cluster.
  1. Click the Configure tab.
  2. Click Clusters from the Budget Manager menu located on the left-hand side of the web page.
  3. Click located to the far right of the cluster.
  4. Click Remove.
  5. Click Remove.
    The cluster is removed.
