Show Parts by ID or Name
Locate parts in the assembly by their ID or name.
- In the Project Tree, select the Assembly workbench.
On the Assembly workbench select .
- In the dialog, select the Find part(s) by ID or Find part(s) by name radio button.
Enter the desired search criteria.
- Use commas to separate multiple inputs.
- Use only integers to search by ID to find parts with matching IDs.
- Use any text input to search by name to find parts with names that contain the searched text. This function is not case sensitive.
Click Find part(s).
Figure 2. Find part(s) by ID: 1, 2, 3, 4
Figure 3. Find part(s) by name: wall, tube
