Altair® Monarch®
Moving a Column
You can move column within a table by:
  • dragging and dropping column headers on the Prepare window.
  • dragging and dropping a column handle on the Column List dialog box.
Moving a column via Drag and Drop
  1. Do one of the following:
    • Select the header of the column you want to move
    • Group-select the columns you want to move by selecting column headers using SHIFT+Click (to select a block of columns) or CTRL+Click (to select individual columns).
  1. Drag the column(s) to their new position. Use the blue arrow to guide you in positioning the new column(s):
Moving a column using the Column List dialog
  1. On the Prepare window, right click on a column and then select Column List from the context menu. The Column List dialog displays.
  2. Select the handle beside the column you want to move:
and drag it to its new position:
  1. Select OK.
Related Links
