Split
Use the Split tools to split a cage with a loop or split a single PolyNURBS cage face.
![](../../../images/icons/inspire/icon_polynurbs_split.png)
Split Cage with Loop
Draw an edge loop around a cage, subdividing the PolyNURBS object to gain more control when editing the cage.
Split Faces
Split a single PolyNURBS cage face.
Keyboard Shortcuts & Mouse Controls
To | Do this | Notes |
Temporarily disable snaps (PolyNURBS tool) | Alt | |
Change the transparency of the underlying shape (STL or optimization result) | Alt+middle mouse scroll | |
Add to or remove from the selection Select a loop an enter editing mode |
Ctrl | |
Delete a selected split or loop | Delete | |
Exit tool | Right-click and mouse through the check mark to exit, or double-right-click. |
