Shape Variable
Use the Shape Variable tool to define which directions PolyNURBS cage points can move during PolyNURBS optimization.
Create a Shape Variable
Select cage points to create a shape variable.
Apply shape variables to locations where you want the PolyNURBS surface to be modified. Specifically, you select existing cage points, allowing those points to move in a specified direction during optimization. Each shape variable will move along one axis. If you want cage points to move in different directions, you should create multiple shape variables.
- Select a shape variable in the legend or modeling window to edit it.
- Red cage points are locked and can't be used in a shape variable, generally because they are included in a fillet or Boolean operation.
- Creating more shape variables will generally produce a more precise result, but the optimization will take longer to run. If you want to maintain the basic shape of the PolyNURBS, use fewer shape variables.
