Pave
Use the Pave tool to create faces manually on an existing object.
- Blend two PolyNURBS surfaces
- Close holes in PolyNURBS geometry
- Convert PolyNURBS surfaces to solids
Pave an Optimized Shape
Pave a surface by placing points along the contour of an optimized shape.
Click the Pave icon.
- Place four points to draw a rectangle. A PolyNURBS surface is automatically created
- To add another face to the PolyNURBS surface, click an open edge on the surface, and then place two more points.
- Repeat the process to pave additional surfaces.
