Add/Remove Blocks to Cage
Use the +/- tool to quickly build the basic shape of a PolyNURBS object by adding a block to the face of an existing cage. You can also remove blocks.
On the Geometry ribbon, in the
Create group, click the PolyNURBS tool, and then click the +/- tool.
Choose from the following options:
- To add a block, click the face of an existing cage.
- To remove a block, hold down Shift while clicking the block.
