/VERS
Engine Keyword Identifies the input data version number.
/VERS/Version Number
| Field | Content | SI Unit Example |
| Version Number | Radioss Input Manual Version 110 |
- This keyword is compulsory.
- This option represents the input format version for Radioss Engine.
- The number version must be coherent with the number version in Radioss Starter.
- The Radioss Engine and Starter Input files must have an extension corresponding to the format used (refer to the Starter Input manual).
