Time Step Control Stability
The stability conditions of explicit scheme in SPH formulation can be written over cells or on nodes.
Cell Time Step
In case of cell stability computation (when no nodal time step is used), the stable time step is computed as:(1)
Δ t = Δ t s c a min i ( d i c i ( α i + α i 2 + 1 ) ) , w i t h α i = ( q b + q a μ ¯ i d i c i ) , a n d μ ¯ i = max j ( μ i j )
Δ t s c a is the user-defined coefficient (Radioss option /DT or /DT/SPHCEL). The value of Δ T sca =0.3 is recommended. 1
Nodal Time Step
In case of nodal time step, stability time step is computed in a more robust way:(2)
Δ t i = 2 m i K i at particle i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@
Use the following notations, if kernel correction:(3)
W j ( i ) = W ^ ( x i x j d i + d j 2 ) a n d W j ( i ) = g r a d | x i [ W ^ ( x x j d i + d j 2 ) ]
Or, if no kernel correction:(4)
W j ( i ) = W ( x i x j d i + d j 2 ) a n d W j ( i ) = g r a d | x i [ W ( x x j d i + d j 2 ) ]
Recalling that apart from the artificial viscosity terms:(5)
F i = j F i j , F i j = V i V j [ p i W j ( i ) p j W j ( j ) ]
write (6)
| K i j | = d F i j d ( u i u j ) d d ( u i u j ) ( V i V j [ p i W j ( i ) + p j W i ( j ) ] )
Where, u i u j is the relative displacement of particles i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ and j MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ . Keeping the only first order terms leads to:(7)
| K i j | V i V j [ d p i d ( u i u j ) W j ( i ) + d p j d ( u i u j ) W i ( j ) ]
Where, (8)
V i V j d p i d ( u i u j ) W j ( i ) = V i V j d p i d ρ i d ρ i d ( u i u j ) W j ( i ) = V i V j c i 2 d ρ i d ( u i u j ) W j ( i )
that is(9)
V i V j d p i d ( u i u j ) W j ( i ) = m i c i 2 V ˙ j 2 W j ( i ) 2
Same reasoning leads to:(10)
V i V j d p j d ( u i u j ) W i ( j ) = m j c j 2 V ˙ i 2 W i ( j ) 2
So that (11)
| K i j | m i c i 2 V ˙ j 2 W j ( i ) 2 + m j c j 2 V ˙ i 2 W i ( j ) 2
Stiffness around node i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ is then estimated as:(12)
| K i | j | K i j |
1 Monaghan J.J., “Smoothed Particle Hydrodynamics”, Annu.Rev.Astron.Astro-phys; Vol. 30; pp. 543-574, 1992.
