Corrected SPH formulation
1
2 has been introduced in order to satisfy the
so-called consistency conditions:
(1)
(2)
These equations insure that the integral approximation of a
function f coincides with f for constant and linear functions of space.
CSPH is a
correction of the kernel functions:
(3)
with
Where the parameters
and
are evaluated by enforcing the consistency condition, now given by the
point wise integration as:
(4)
(5)
These equations enable the explicit evaluation of the correction
parameters
and
as:
(6)
(7)
Since the evaluation of gradients of corrected kernel (which are
used for the SPH integration of continuum equations) becomes very expensive, corrected SPH
limited to order 0 consistency has been introduced. Therefore, the kernel correction reduces
to the following equations:
(8)
that is
(9)
(10)
Note: SPH corrections generally insure a better representation even if the
particles are not organized into a hexagonal compact net, especially close to the
integration domain frontiers. SPH corrections also allow the smoothing length
to values different to the net size
to be set.
