It can be shown that the SPH method is unstable in tension. The instability is shown to
result from an effective stress with a negative modulus (imaginary sound speed)
being produced by the interaction between the constitutive relation and the kernel
function, and is not caused by the numerical time integration algorithm.
1 D.S Balsara
2 states, use special filtering of
velocities (so called
conservative smoothing, because momentum
quantities are not modified):
(1)
