Jetting Effect
The jetting effect is modeled as an overpressure applied to each element of the airbag (Figure 1).(1)
Δ P j e t = Δ P 1 ( t ) . Δ P 2 ( θ ) . Δ P 3 ( δ ) . max ( n . n 1 , 0 )
with:
n 1
Being the normalized vector between the projection of the center of the element upon segment ( N 1 , N 3 ) and the center of element as shown in Figure 1.
θ
The angle between the vector M N 2 and the vector n 1 .
δ
The distance between the center of the element and its projection of a point upon segment ( N 1 , N 3 ).
The projection upon the segment ( N 1 , N 3 ) is defined as the projection of the point in direction M N 2 upon the line ( N 1 , N 3 ) if it lies inside the segment ( N 1 , N 3 ). If this is not the case, the projection of the point upon segment ( N 1 , N 3 ) is defined as the closest node N 1 or N 3 . If N 3 coincides to N 1 , the dihedral shape of the jet is reduced to a conical shape.
Figure 1. Jetting Effect Schema
