Model Instrumentation
The outputs and storage frequencies must be set to get enough information for post-processing results.
Variables To Save
To find the origin of problems, you need output files with enough information, especially for the most potentially problematic entities as springs, interfaces and rigid bodies.
Springs
Save all spring and beam elements (except for spring of spot welds)
/TH/SPRING
Measure displacements and forces inside specific spring
Example: engine mount, subframe, fixation, etc.
Interfaces
Save all contact interfaces (except for TYPE 2)
/TH/INTER
Output the forces of the specific interfaces
Example: dummy/belt
Rigid Bodies
Measure the displacement and force inside specific rigid bodies
Example: subframe fixations, engine mount, etc.
Section, Rigid Wall and Monitored Volume
Save all TH outputs
Set the Radioss Engine deck to save variables in animation files:
Mass
/ANIM/MASS
Nodal mass variation
/ANIM/NODA/DMAS
Plastic Strain
/ANIM/ELEM/EPSP
von Mises
/ANIM/ELEM/VONM
Hourglass
/ANIM/ELEM/HOURG
Specific energy
/ANIM/ELEM/ENER
Velocity
/ANIM/VECT/VEL
Contacts
/ANIM/VECT/CONT
Force on rigid wall
/ANIM/VECT/FOPT
In addition, /ANIM/VECT/ACC and /ANIM/VECT/FINT may be useful in case of a problem.
Note: Be sure to get an animation file when a run fails; you can use the /STOP option in the Engine file. If the computation stops, run another restart and write an animation in the first cycle.
