/ANIM/SHELL/SIG2H
Engine Keyword Generates animation files containing the second normalized principal stress as function of a shell element integration point.
/ANIM/SHELL/SIG2H/Keyword4
Data | Description | SI Unit Example |
Keyword4 | Output location.
- In case of BATOZ shell element, the value is the average value of the Gauss points in the layer.
