AIRBAG1
Uniform pressure is assumed inside the volume. Perfect gas law and adiabatic conditions are assumed. Injected mass (or mass flow rate) and temperature are defined as a time function using the injector property. A sensor can define the inflator starting time.
The deflation of the vent hole occurs after reaching a pressure ( P d e f MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWG0bWaaS baaSqaaiaadsgacaWGLbGaamOzaaqabaaaaa@3A42@ ) or time ( t d e f MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWG0bWaaS baaSqaaiaadsgacaWGLbGaamOzaaqabaaaaa@3A42@ ) criteria.
Numerical Damping
Viscosity, μ can be used to reduce numerical oscillations.
If μ =1, a critical damping (shell mass and volume stiffness) is used. A viscous pressure, q MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGXbaaaa@3755@ is computed as:
q = μ A P A ρ t V d V d t MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGXbGaey ypa0JaeyOeI0YaaSaaaeaacqaH8oqBaeaacaWGbbaaamaakaaabaWa aSaaaeaacaWGqbGaamyqaiabeg8aYjaadshaaeaacaWGwbaaaaWcbe aakmaalaaabaGaamizaiaadAfaaeaacaWGKbGaamiDaaaaaaa@44EE@ if d V d t < 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaadaWcaaqaai aadsgacaWGwbaabaGaamizaiaadshaaaGaeyipaWJaaGimaaaa@3BD3@
q = 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGXbGaey ypa0JaaGimaaaa@3915@ if dV dt >0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaadaWcaaqaai aadsgacaWGwbaabaGaamizaiaadshaaaGaeyOpa4JaaGimaaaa@3BD7@
Where,
t MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWG0baaaa@3758@
Fabric thickness
ρ
Density of the fabric
A MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWG0baaaa@3758@
Bag surface
The applied pressure is:(1)
P P e x t + q
Initial Conditions
To avoid initial disequilibrium and mathematical discontinuity for zero mass or zero volume, the following initial conditions are set at time zero (Iequil =0) or at the beginning of jetting (if Iequil =1).
  • P e x t = P i n i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuamaaBa aaleaacaWGLbGaamiEaiaadshaaeqaaOGaeyypa0JaamiuamaaBaaa leaacaWGPbGaamOBaiaadMgaaeqaaaaa@3EB7@ external pressure
  • T 0 = T i n i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamivamaaBa aaleaacaaIWaaabeaakiabg2da9iaadsfadaWgaaWcbaGaamyAaiaa d6gacaWGPbaabeaaaaa@3C99@ initial temperature (295K by default)
  • If the initial volume is less than 10 4 A 3 2 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaaIXaGaaG imamaaCaaaleqabaGaeyOeI0IaaGinaaaakiaadgeadaahaaWcbeqa amaaliaabaGaaG4maaqaaiaaikdaaaaaaaaa@3C34@ , a constant small volume is added to obtain an initial volume: V i n i = 10 4 A 3 2 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGwbWaaS baaSqaaiaadMgacaWGUbGaamyAaaqabaGccqGH9aqpcaaIXaGaaGim amaaCaaaleqabaGaeyOeI0IaaGinaaaakiaadgeadaahaaWcbeqaam aaliaabaGaaG4maaqaaiaaikdaaaaaaaaa@411A@
  • Initial mass, energy and density are defined from the above values.
There is no need to define an injected mass at time zero.
Gases Definition
  1. Initial and injected gas is defined with /MAT/GAS. Four types of gas (MASS, MOLE, PREDEF, or CSTA) could be defined. Then the specific capacity per unit mass at constant pressure for the gas is:
    • MASS type(2)
      C p = ( C p a + C p b T + C p c T 2 + C p d T 3 + C p e T 2 + C p f T 4 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGdbWaaS baaSqaaiaadchaaeqaaOGaeyypa0ZaaeWaceaacaWGdbWaaSbaaSqa aiaadchacaWGHbaabeaakiabgUcaRiaadoeadaWgaaWcbaGaamiCai aadkgaaeqaaOGaaGjbVlaadsfacqGHRaWkcaWGdbWaaSbaaSqaaiaa dchacaWGJbaabeaakiaaysW7caWGubWaaWbaaSqabeaacaaIYaaaaO Gaey4kaSIaam4qamaaBaaaleaacaWGWbGaamizaaqabaGccaaMe8Ua amivamaaCaaaleqabaGaaG4maaaakiabgUcaRmaalaaabaGaam4qam aaBaaaleaacaWGWbGaamyzaaqabaaakeaacaWGubWaaWbaaSqabeaa caaIYaaaaaaakiabgUcaRiaadoeadaWgaaWcbaGaamiCaiaadAgaae qaaOGaaGjbVlaadsfadaahaaWcbeqaaiaaisdaaaaakiaawIcacaGL Paaaaaa@5EC1@
    • MOLE type(3)
      C p = 1 M W ( C p a + C p b T + C p c T 2 + C p d T 3 + C p e T 2 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGdbWaaS baaSqaaiaadchaaeqaaOGaeyypa0ZaaSaaaeaacaaIXaaabaGaamyt aiaadEfaaaWaaeWaceaacaWGdbWaaSbaaSqaaiaadchacaWGHbaabe aakiabgUcaRiaadoeadaWgaaWcbaGaamiCaiaadkgaaeqaaOGaaGjb VlaadsfacqGHRaWkcaWGdbWaaSbaaSqaaiaadchacaWGJbaabeaaki aaysW7caWGubWaaWbaaSqabeaacaaIYaaaaOGaey4kaSIaam4qamaa BaaaleaacaWGWbGaamizaaqabaGccaaMe8UaamivamaaCaaaleqaba GaaG4maaaakiabgUcaRmaalaaabaGaam4qamaaBaaaleaacaWGWbGa amyzaaqabaaakeaacaWGubWaaWbaaSqabeaacaaIYaaaaaaaaOGaay jkaiaawMcaaaaa@5A1F@
      Where, M W MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbGaam 4vaaaa@380C@ is the molecular weight of the gas.
    • CSTA type
      User input C p MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGdbWaaS baaSqaaiaadchaaeqaaaaa@3847@ and C V MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGdbWaaS baaSqaaiaadchaaeqaaaaa@3847@ with the unit of [ J k g K ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaadaWadaqaam aalaaabaGaamOsaaqaaiaadUgacaWGNbGaam4saaaaaiaawUfacaGL Dbaaaaa@3BDB@ .
    • PREDEF type
      About 14 commonly used gases (N2, O2, Air, etc) predefined in Radioss.
  2. Injected gas
    Njet defines the number of injectors by monitored volume. The material of the injected gas is defined with /MAT/GAS. The injector properties (/PROP/INJECT1 or /PROP/INJECT2) define the injected mass curve defined fct_IDM and injected temperature curve defined fct_IDT.
    Injected mass curve and injection temperature can be obtained:
    • From the airbag manufacturer
    • From a tank test
    sens_ID is the sensor number to start injection.
  3. Jetting effect Ijet is used only for /MONVOL/AIRBAG1 or /MONVOL/COMMU1
    If Ijet ≠ 0, the jetting effect is modeled as an overpressure Δ P j e t applied to elements of the bag.(4)
    Δ P j e t = Δ P ( t ) Δ P ( θ ) Δ P ( δ ) max ( n · m , 0 ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqqHuoarca WGqbWaaSbaaSqaaiaadQgacaWGLbGaamiDaaqabaGccqGH9aqpcqqH uoarciGGqbWaaeWaaeaacaWG0baacaGLOaGaayzkaaGaeyyXICTaeu iLdqKaciiuamaabmaabaGaeqiUdehacaGLOaGaayzkaaGaeyyXICTa euiLdqKaciiuamaabmaabaGaeqiTdqgacaGLOaGaayzkaaGaeyyXIC TaciyBaiaacggacaGG4bWaaeWaaeaacaWHUbGaeS4JPFMaaCyBaiaa cYcacaaIWaaacaGLOaGaayzkaaaaaa@5D4D@
    N1, N2, and N3 are defined based on the injector geometry (refer to the Radioss Starter Input Manual)
    Δ P ( t ) , Δ P ( θ ) , Δ P ( δ ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqqHuoarci GGqbWaaeWaaeaacaWG0baacaGLOaGaayzkaaGaaiilaiabfs5aejGa ccfadaqadaqaaiabeI7aXbGaayjkaiaawMcaaiaacYcacqqHuoarci GGqbWaaeWaaeaacqaH0oazaiaawIcacaGLPaaaaaa@4762@ are empirical functions provided by the user via f c t _ I D P t MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGMbGaam 4yaiaadshacaGGFbGaamysaiaadseadaWgaaWcbaGaamiuaiaadsha aeqaaaaa@3D9F@ , f c t _ I D P θ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGMbGaam 4yaiaadshacaGGFbGaamysaiaadseadaWgaaWcbaGaamiuaiabeI7a Xbqabaaaaa@3E5C@ , and f c t _ I D P δ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGMbGaam 4yaiaadshacaGGFbGaamysaiaadseadaWgaaWcbaGaamiuaiabes7a Kbqabaaaaa@3E4B@
Vent Hole Definition
Nvent defines the number of vent holes used.
s u r f _ I D v MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGZbGaam yDaiaadkhacaWGMbGaai4xaiaadMeacaWGebWaaSbaaSqaaiaadAha aeqaaaaa@3DD4@ is the surface identifier defining the vent hole
Avent is the vent area (if s u r f _ I D v = 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGZbGaam yDaiaadkhacaWGMbGaai4xaiaadMeacaWGebWaaSbaaSqaaiaadAha aeqaaOGaeyypa0JaaGimaaaa@3F9E@ ) or a scale factor ( s u r f _ I D v MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGZbGaam yDaiaadkhacaWGMbGaai4xaiaadMeacaWGebWaaSbaaSqaaiaadAha aeqaaaaa@3DD4@ ≠ 0)
Bvent = 0 (if s u r f _ I D v = 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGZbGaam yDaiaadkhacaWGMbGaai4xaiaadMeacaWGebWaaSbaaSqaaiaadAha aeqaaOGaeyypa0JaaGimaaaa@3F9E@ ) or a scale factor on the impacted surface ( s u r f _ I D v MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGZbGaam yDaiaadkhacaWGMbGaai4xaiaadMeacaWGebWaaSbaaSqaaiaadAha aeqaaaaa@3DD4@ ≠ 0)
Tstop is a stop time for venting
Tstart is the time at which leakage starts
Δ P d e f is the relative vent deflation pressure
Δt P def MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqqHuoarca WG0bGaamiuamaaBaaaleaacaWGKbGaamyzaiaadAgaaeqaaaaa@3C7D@ is the time duration during which Δ P > Δ P d e f
f c t _ I D v MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGMbGaam 4yaiaadshacaGGFbGaamysaiaadseadaWgaaWcbaGaamODaaqabaaa aa@3CCC@ is the function identifier f P ( P P e x t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGMbWaaS baaSqaaiaadcfaaeqaaOWaaeWaaeaacaWGqbGaeyOeI0Iaamiuamaa BaaaleaacaWGLbGaamiEaiaadshaaeqaaaGccaGLOaGaayzkaaaaaa@3F8C@ for Chemkin model (Iform=2)(5)
vent_holes_surface = A vent A non_impacted f t ( t ) f P ( P P ext ) f A ( A non_impacted A 0 ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaqaaaaaaaaa WdbiaadAhacaWGLbGaamOBaiaadshacaGGFbGaamiAaiaad+gacaWG SbGaamyzaiaadohacaGGFbGaam4CaiaadwhacaWGYbGaamOzaiaadg gacaWGJbGaamyzaiaabccacqGH9aqppaGaamyqamaaBaaaleaacaWG 2bGaamyzaiaad6gacaWG0baabeaakiabgwSixlaadgeadaWgaaWcba GaamOBaiaad+gacaWGUbGaai4xaiaadMgacaWGTbGaamiCaiaadgga caWGJbGaamiDaiaadwgacaWGKbaabeaakiabgwSixlGacAgadaWgaa WcbaGaamiDaaqabaGcdaqadaqaaiaadshaaiaawIcacaGLPaaacqGH flY1ciGGMbWaaSbaaSqaaiaadcfaaeqaaOWaaeWaaeaacaWGqbGaey OeI0IaamiuamaaBaaaleaacaWGLbGaamiEaiaadshaaeqaaaGccaGL OaGaayzkaaGaeyyXICTaciOzamaaBaaaleaacaWGbbaabeaakmaabm aabaWaaSaaaeaacaWGbbWaaSbaaSqaaiaad6gacaWGVbGaamOBaiaa c+facaWGPbGaamyBaiaadchacaWGHbGaam4yaiaadshacaWGLbGaam izaaqabaaakeaacaWGbbWaaSbaaSqaaiaaicdaaeqaaaaaaOGaayjk aiaawMcaaaaa@8254@
If f c t _ I D v 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGMbGaam 4yaiaadshacaGGFbGaamysaiaadseadaWgaaWcbaGaamODaaqabaGc cqGHGjsUcaaIWaaaaa@3F57@ , the outflow velocity, v MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaaleaacaWG2baaaa@375B@ is defined by Chemkin as:(6)
v = F s c a l e v f v ( P P e x t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWG2bGaey ypa0JaamOraiaadohacaWGJbGaamyyaiaadYgacaWGLbWaaSbaaSqa aiaadAhaaeqaaOGaciOzamaaBaaaleaacaWG2baabeaakmaabmaaba GaamiuaiabgkHiTiaadcfadaWgaaWcbaGaamyzaiaadIhacaWG0baa beaaaOGaayjkaiaawMcaaaaa@4850@
Where, F s c a l e v MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGgbGaam 4CaiaadogacaWGHbGaamiBaiaadwgadaWgaaWcbaGaamODaaqabaaa aa@3CF2@ is the scale factor of the function f c t _ I D v MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGMbGaam 4yaiaadshacaGGFbGaamysaiaadseadaWgaaWcbaGaamODaaqabaaa aa@3CCC@ .
and the outgoing mass is computed as:(7)
m ˙ out =ρ A vent f v ( P P ext )Fscal e v MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaceWGTbGbai aadaWgaaWcbaGaam4BaiaadwhacaWG0baabeaakiabg2da9iabeg8a YjabgwSixlaadgeadaWgaaWcbaGaamODaiaadwgacaWGUbGaamiDaa qabaGccqGHflY1ciGGMbWaaSbaaSqaaiaadAhaaeqaaOWaaeWaaeaa caWGqbGaeyOeI0IaamiuamaaBaaaleaacaWGLbGaamiEaiaadshaae qaaaGccaGLOaGaayzkaaGaeyyXICTaamOraiaadohacaWGJbGaamyy aiaadYgacaWGLbWaaSbaaSqaaiaadAhaaeqaaaaa@58CE@
Or, with the conservation of enthalpy between airbag and vent hole, adiabatic conditions and unshocked flow, it is then possible to express outgoing mass flow through vent holes as a function of P e x t MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuamaaBa aaleaacaWGLbGaamiEaiaadshaaeqaaaaa@39D7@ , ρ , P v e n t MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuamaaBa aaleaacaWG2bGaamyzaiaad6gacaWG0baabeaaaaa@3AC8@ , u v e n t MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyDamaaBa aaleaacaWG2bGaamyzaiaad6gacaWG0baabeaaaaa@3AED@ and A v e n t MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyqamaaBa aaleaacaWG2bGaamyzaiaad6gacaWG0baabeaaaaa@3AB9@ .(8)
m ˙ out = ρ vent A vent u=ρ ( P ext P ) 1 γ A vent u MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaceWGTbGbai aadaWgaaWcbaGaam4BaiaadwhacaWG0baabeaakiabg2da9iabeg8a YnaaBaaaleaacaWG2bGaamyzaiaad6gacaWG0baabeaakiabgwSixl aadgeadaWgaaWcbaGaamODaiaadwgacaWGUbGaamiDaaqabaGccqGH flY1caWG1bGaeyypa0JaeqyWdi3aaeWaaeaadaWcaaqaaiaadcfada WgaaWcbaGaamyzaiaadIhacaWG0baabeaaaOqaaiaadcfaaaaacaGL OaGaayzkaaWaaWbaaSqabeaadaWcaaqaaiaaigdaaeaacqaHZoWzaa aaaOGaeyyXICTaamyqamaaBaaaleaacaWG2bGaamyzaiaad6gacaWG 0baabeaakiabgwSixlaadwhaaaa@61C2@
In the case of supersonic outlet flow, the vent pressure, P v e n t MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuamaaBa aaleaacaWG2bGaamyzaiaad6gacaWG0baabeaaaaa@3AC8@ is equal to external pressure, P e x t MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuamaaBa aaleaacaWGLbGaamiEaiaadshaaeqaaaaa@39D7@ for unshocked flow. For shocked flow, P v e n t MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuamaaBa aaleaacaWG2bGaamyzaiaad6gacaWG0baabeaaaaa@3AC8@ is equal to critical pressure, P c r i t MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuamaaBa aaleaacaWGJbGaamOCaiaadMgacaWG0baabeaaaaa@3ABD@ and velocity, u MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyDaaaa@36F0@ is bounded to critical sound speed:(9)
u 2 < 2 γ+1 c 2 = 2γ γ+1 P ρ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWG1bWaaW baaSqabeaacaaIYaaaaOGaeyipaWZaaSaaaeaacaaIYaaabaGaeq4S dCMaey4kaSIaaGymaaaacaWGJbWaaWbaaSqabeaacaaIYaaaaOGaey ypa0ZaaSaaaeaacaaIYaGaeq4SdCgabaGaeq4SdCMaey4kaSIaaGym aaaadaWcaaqaaiaadcfaaeaacqaHbpGCaaaaaa@489D@
and(10)
P c r i t = P ( 2 γ + 1 ) γ γ 1
(11)
P v e n t = max ( P c r i t , P e x t )
The outgoing mass flow of gas i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ is:(12)
m ˙ out ( i ) = V ( i ) V m ˙ out MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaceWGTbGbai aadaWgaaWcbaGaam4BaiaadwhacaWG0baabeaakmaaCaaaleqabaWa aeWaaeaacaWGPbaacaGLOaGaayzkaaaaaOGaeyypa0ZaaSaaaeaaca WGwbWaaWbaaSqabeaadaqadaqaaiaadMgaaiaawIcacaGLPaaaaaaa keaacaWGwbaaaiqad2gagaGaamaaBaaaleaacaWGVbGaamyDaiaads haaeqaaaaa@46AD@
Where, V ( i ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvamaaCa aaleqabaGaaiikaiaadMgacaGGPaaaaaaa@3945@ is the volume occupied by gas i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ and satisfies:(13)
V ( i ) = n ( i ) n V MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGwbWaaW baaSqabeaadaqadaqaaiaadMgaaiaawIcacaGLPaaaaaGccqGH9aqp daWcaaqaaiaad6gadaahaaWcbeqaamaabmaabaGaamyAaaGaayjkai aawMcaaaaaaOqaaiaad6gaaaGaamOvaaaa@406D@
from P V ( i ) = n ( i ) R T MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGqbGaam OvamaaCaaaleqabaWaaeWaaeaacaWGPbaacaGLOaGaayzkaaaaaOGa eyypa0JaamOBamaaCaaaleqabaWaaeWaaeaacaWGPbaacaGLOaGaay zkaaaaaOGaamOuaiaadsfaaaa@4114@ and P V = [ i n ( i ) ] R T MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGqbGaam Ovaiabg2da9maadmaabaWaaabuaeaacaWGUbWaaWbaaSqabeaadaqa daqaaiaadMgaaiaawIcacaGLPaaaaaaabaGaamyAaaqab0GaeyyeIu oaaOGaay5waiaaw2faaiaadkfacaWGubaaaa@435E@ .
Then,(14)
m ˙ o u t ( i ) = n ( i ) i n ( i ) m ˙ o u t MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaceWGTbGbai aadaWgaaWcbaGaam4BaiaadwhacaWG0baabeaakmaaCaaaleqabaWa aeWaaeaacaWGPbaacaGLOaGaayzkaaaaaOGaeyypa0ZaaSaaaeaaca WGUbWaaWbaaSqabeaadaqadaqaaiaadMgaaiaawIcacaGLPaaaaaaa keaadaaeqbqaaiaad6gadaahaaWcbeqaamaabmaabaGaamyAaaGaay jkaiaawMcaaaaaaeaacaWGPbaabeqdcqGHris5aaaakiqad2gagaGa amaaBaaaleaacaWGVbGaamyDaiaadshaaeqaaaaa@4C91@
Porosity
The isenthalpic model is also used for porosity. In this case, you can define the surface for outgoing flow:(15)
A eff = C ps Are a ps MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGbbWaaS baaSqaaiaadwgacaWGMbGaamOzaaqabaGccqGH9aqpcaWGdbWaaSba aSqaaiaadchacaWGZbaabeaakiabgwSixlaadgeacaWGYbGaamyzai aadggadaWgaaWcbaGaamiCaiaadohaaeqaaaaa@45FC@
or, (16)
A eff = C ps (t) Area ps (P P ext ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGbbWaaS baaSqaaiaadwgacaWGMbGaamOzaaqabaGccqGH9aqpciGGdbWaaSba aSqaaiaadchacaWGZbaabeaakiaacIcacaWG0bGaaiykaiabgwSixl GacgeacaGGYbGaaiyzaiaacggadaWgaaWcbaGaamiCaiaadohaaeqa aOGaaiikaiaadcfacqGHsislcaWGqbWaaSbaaSqaaiaadwgacaWG4b GaamiDaaqabaGccaGGPaaaaa@4F5D@
Where,
C ps (t) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGdbWaaS baaSqaaiaadchacaWGZbaabeaakiaacIcacaWG0bGaaiykaaaa@3B9D@
Function of fct_IDcps
Area ps (P P ext ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGbbGaai OCaiaacwgacaGGHbWaaSbaaSqaaiaadchacaWGZbaabeaakiaacIca caWGqbGaeyOeI0IaamiuamaaBaaaleaacaWGLbGaamiEaiaadshaae qaaOGaaiykaaaa@4313@
Function of fct_IDaps
It is also possible to define closure of the porous surface when contacts occurs by defining the interface option Ibag=1.
