PARAM, SH4NRP
Bulk Data Entry This parameter controls the full projection of 4-node shell elements in NLGEOM implicit analysis.
| Parameter | Values | Description |
| SH4NRP | 0,
1, 2 Default = 0 in NLGEOM subcase Default = 1 in IMPDYN subcase |
In the case of finite rigid rotations with warped shell elements, PARAM, SH4NRP, 1 gives accurate results. If convergence difficulties are encountered, PARAM, SH4NRP, 2 should be used. If PARAM, SMDISP, 1 is present, SH4NRP is always set as 0 internally. |
