PARAM, I64SLV
Bulk Data Entry Enforces the activation of internal long (64-bit) integer sparse direct solver.
Parameter Values Description
I64SLV <YES, NO>
Default = NO
This parameter is used to enforce the activation of internal long (64-bit) integer sparse direct solver. With automatic memory allocation mode, the solver automatically decides whether or not to switch the 64-bit integer solver on. However, even if the 64-bit integer solver is not the preferred choice in certain scenarios, this parameter can still be used to enforce activation.
YES
The long (64-bit) integer sparse direct solver is used.
NO
The short (32-bit) integer sparse direct solver is used.
