RADPRM, SH4NRP
Bulk Data Entry Controls the full projection of 4-node shell elements in NLGEOM implicit analysis.
| Parameter | Values | Description |
| SH4NRP | <0,
1, or 2> Default = 0 in NLGEOM subcase Default = 1 in IMPDYN subcase |
In the case of finite rigid rotations with warped shell elements, RADPRM, SH4NRP, 1 provides accurate results. If convergence difficulties are encountered, RADPRM, SH4NRP, 2 should be used. If RADPRM, SMDISP is present, SH4NRP is always set as 0 internally. |
