RADPRM, SMDISP
Bulk Data Entry The RADPRM, SMDISP parameter is used to specify if small displacement formulation or large displacement formulation is used.
Table 1. Definitions
Parameter Values Description
SMDISP <0, 1> When large displacement effects are negligible, RADPRM, SMDISP, 1 can be used to improve the convergence and performance.
0 (Default)
Use large displacement formulation.
1
Use small displacement formulation.
