Motion: Marked Based
Command ElementModifies a marker motion element.
<Motion_Marker
id = "integer"
i_marker_id = "integer"
j_marker_id = "integer"
direction = { "X" | "Y" | "Z" | "B1" | "B2" | "B3" }
val_type = "D"
val_type = "V"
ic_disp = "real"
val_type = "A"
ic_disp = "real"
ic_vel = "real"
type = "EXPRESSION"
expr = "motionsolve_expression" >
type = "USERSUB"
usrsub_dll_name = "valid_path_name"
usrsub_param_string = "USER( [[par_1[,...][,par_n]])
usrsub_fnc_name = "valid_fnc_name"
Attributes
- id
- Element identification number (integer>0). This number is unique among all Motion_Marker elements.
- type
- Select from "EXPRESSION" and "USERSUB". Specifies how the motion expression is defined. The "EXPRESSION" option specifies that the motion value is a MotionSolve expression that can be evaluated at run-time. The "USERSUB" option indicates that the value of the motion is specified in a user defined subroutine. The parameters usrsub_param_string, usrsub_dll_name and usrsub_fnc_name are used to provide more information about the user defined subroutine.
- val_type
- Modifies whether the motion applies a displacement input (D), a velocity input (V), or an acceleration input (A). You must select one option from "D", "V" or "A".
- expr
- Modifies the expression that defines the motion value. Use this parameter only when type = "EXPRESSION". Any valid run-time MotionSolve expression can be provided as input.
- usrsub_param_string
- Modifies the list of parameters that are passed from the data file to the user defined subroutine. Use this keyword only when type = "USERSUB" is selected.
- usrsub_dll_name
- Modifies the path and name of the DLL or shared library containing the user subroutine. MotionSolve uses this information to load the user subroutine in the DLL at run time.
- usrsub_fnc_name
- Modifies an alternative name for the user subroutine MOTSUB.
- i_marker_id
- Modifies the Reference_Marker ID at which the motion input is applied.
- j_marker_id
- Modifies the Reference_Marker ID from which the motion input is applied.
- direction
- Modifies the direction of the input. Select one from "X", "Y", "Z", "B1", "B2", and "B3".
- ic_disp
- Modifies the displacement initial condition that is required when val_type = "V" or val_type = "A".
- ic_vel
- Modifies the velocity initial condition that is required when val_type = "A".
<Motion_Marker
id = "301001"
type = "EXPRESSION"
val_type = "D"
expr = "0.1*SIN(3*TIME)"
i_marker_id = "30105071"
j_marker_id = "30101070"
direction = "Y"
<Motion_Marker
id = "301001"
type = "USERSUB"
val_type = "D"
usrsub_param_string = "USER(5,2)"
usrsub_dll_name = "NULL"
direction = "Y"
