Files Generated During Meshing
When you generate a mesh (Tools > Generate Mesh or on toolbar), files and directories are created. By default, when you generate a mesh, the options for exporting mesh settings and for launching AcuMeshSim are turned on. You can use the Generate Mesh dialog with only the Export option turned on. Information about these files and directories are provided in the following sections.
The files related to mesh settings are discussed first. Once you generate a mesh and save the .acs file, the meshing files can be removed to free up disk space. You will need to regenerate the files if the you would like to see any of the information contained in the files.
