Export Mesh Settings
![](../../../images/icons/icon_acuconsole_mesh.png)
.ams | |
Description | Input file for AcuMeshSim |
Location | Same directory as <problem>.acs |
Name | Same as <problem> name given by you |
File type | ASCII, .xml |
nm.smd | |
Description | Non-manifold geometry file |
Location | \CAD.DIR directory below the location of the .acs file |
Name | Same as the name of the geometry file imported for the problem - <geom>nm.smd |
File type | ASCII |
nat.x_t or nat.x_b | |
Description | Parasolid geometry file |
Name | Same as the name of the geometry file imported for the problem - <geom>nat.x_t or <geom>nat.x_b |
File type | ASCII (.x_t), binary (.x_b) |
