ufpGetUsrVals()
Return the array of user-supplied values.
usrVals = ufpGetUsrVals ( ufpHd ) ;
AcuSolve User-Defined Function Basic Routine
ufpHd (pointer)
The opaque handle which was passed to the user function.
Return Value
The return value is a pointer to one-dimensional real array of user values as given in the input file. This array has ufpGetNumUsrVals() entries.
This routine returns the real array of user-given parameters. The order of the parameters within the array is the same as in the input file. For example,
Real* usrVals ;
Real amp, omega ;
ufpCheckNumUsrVals( ufpHd, 2 ) ;
usrVals = ufpGetUsrVals( ufpHd ) ;
amp     = usrVals[0] ;
omega   = usrVals[1] ;
This routine expects a valid ufpHd.
