Compile, Link and Run
In order for AcuTrace to access the user-defined functions, the functions must be compiled and linked into a shared library. The script acuMakeLib may be used for this purpose.
acuMakeLib -src usrEner.c,usrEnerF.f
This script writes the makefile, Makefile, and invokes make to compile and link the routines. The makefile has two targets, make all, or equivalently make install, and make clean.
acuRunTrace -libs ./libusr.so
acuRunTrace -libs ~/acusim_libs/libener1.so,~/acusim_libs/libener2.so
The libraries are searched sequentially in the order given for the user functions. Libraries that do not exist are ignored. To see what libraries and what routines are accessed by the solver, invoke acuRunTrace with the option -verbose 2.
Note that for most computer platforms, the functions within a given user shared library can access all functions in that library, plus all system and solver functions. However, they may not access functions in other user shared libraries. This behavior is a platform dependent.
Also note that on most platforms the shared library has a .so extension, but on some it may be .sl, such as HP, or .dll, Intel/WIN.
