udfWritePipe()
Write (send) a message to an external program.
udfWritePipe( udfHd, format, ... ) ;
AcuSolve User-Defined Function Client
udfHd
The opaque handle (pointer) which was passed to the user function.
format (string)
C printf() format.
... (vararg)
List of C variable.
Return Value
None
This routine writes (sends) a message to the pipe opened by udfOpenPipe or udfOpenPipePrim. The argument list is the same as that of fprintf(), except that here udfHd takes the place of the file descriptor. For example,
udfWritePipe( udfHd, "pressure= %.16g", -trac[0] ) ;
  • This routine expects a valid udfHd.
  • May only be called from a multiplier function or mesh motion user-defined function.
