udfReadPipe()
Read (receive) a line of data from an external program.
udfreadPipe( udfHd, buffer, buffSize ) ;
AcuSolve User-Defined Function Client
udfHd
The opaque handle (pointer) which was passed to the user function.
buffer (string)
Pointer to the line of data.
buffSize (integer)
Number of bytes in the line of data.
Return Value
None
This routine reads (receives) a message from the pipe opened by udfOpenPipe or udfOpenPipePrim. For example,
udfReadPipe( udfHd, &buffer, 1024 ) ;
  • This routine expects a valid udfHd.
  • May only be called from a multiplier function or mesh motion user-defined function.
